drsteve
Mar 28, 2019Explorer
starcraft69 wrote:drsteve wrote:hypoxia wrote:
Just keep in mind the air filter is meant to remove large particulates and allow small particulates to pass through the evaporator. It is not meant to clean the air you breathe. A "paper filter" by its very nature will create a large restriction, reduce air flow and increase head pressure in the compressor. That is not a good thing.
What he said. A paper filter will be a significant flow restriction.
What they say. Plus this will more then likely cause freezing and icing.
That too.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
