wopachop
Mar 29, 2019Explorer
I was going to try this last year. Already have the filters and dont care what it looks like up there. Plan was to fold and staple a larger pleated filter into a box like shape and temp tape it to the roof. If i like it then maybe build a housing the accept a flat filter for easy replacement.
I got to think at some point a person with hvac experience has tinkered with their RV and measured the flow of a clean stock foam filter? Or maybe there is a spec on what the stock filter flows?
If we know the stock filter specs then it would be somewhat safe to use a residential pleated filter with equal flow at the correct velocity the RV a/c runs at on high?
Its dusty here and i want to keep the ducts clean is my motivation. I have an automotive radiator fan hot glued to a cardboard box with a pleated filter on it. Sometimes stick in the window and other times run in the trailer as an air filter.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
