garyemunson's avatar
garyemunson
Explorer II
Mar 28, 2019
Paper air filter conversion
Does anyone sell a conversion kit to allow using a disposable paper filter on a Coleman A/C? Looks like a 16" x 16" filter would be the size. Otherwise I feel a project coming on.
  • Just keep in mind the air filter is meant to remove large particulates and allow small particulates to pass through the evaporator. It is not meant to clean the air you breathe. A "paper filter" by its very nature will create a large restriction, reduce air flow and increase head pressure in the compressor. That is not a good thing.
    You probably will have much less air flow, maybe you could build a larger frame for a larger paper filter.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
