- sdmotorExplorerJust swapped my wfco for the pro 9200 80amp in my new to me class a. I put one in my toyhauler and water depletion in my batteries went way down. I also had 5 yrs on my batts that were still going strong when I sold it thanks to that converter.
- Fleet_ManExplorerDid the PD9260 swap several years ago, very easy straight forward task. No more boiled house batteries. Get the Wizard pendant if it is not included in the deal.
- MrWizardModeratormoved from technology
- ScottGNomadThere's no contest. Go Pro.
- 9260, possibly 4655
- rvtenExplorerGo with the Pro. Much better unit. Changed mine earlier this year.
I suggest taking pictures of the wiring before. Make sure you number all the wires. On mine they were all red or green. - midnightsadieExplorer III had the same set up as you, yes the pro is better easy hook up ,my 18teen yr old grandson and I did it in about two hrs, no problems. and it worked perfect. charges much better to.
