Salvo
May 17, 2014Explorer
1. Find R32.
2. Lift the lead of R32 that's closer to the transformer out of the circuit board.
3. Solder a small signal diode (anode side) into the circuit board hole where the lead of R32 was removed.
4. Solder the cathode side of diode (it has the black band) to the lifted side of R32. Both the diode and R32 are angled up into the air.
5. Solder a 100 ohm, 1/8W resistor to the junction of diode and R32.
6. Solder bell wire (or whatever wire you have) from the other side of the 100 ohm resistor to the battery. This wire conducts very little current.
When the battery is thirsty, the diode clamps max voltage to about 0.5V above regulation, or to about 14.3V at the output of the converter. The battery voltage will charge to regulation (13.7V).
Sal
Sal
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
