full_mosey
Mar 23, 2015Explorer
pnichols wrote:BFL13 wrote:
We won't talk about how I stuck the Paramode's temp comp wire sensor ring terminal in some ice cream to get the charging voltage higher.
It's good experimental procedure to do that "in a lab" for making measurements ... but probably shouldn't be used when camping .... ESPECIALLY IN WARM WEATHER to make charging voltages even more dangerously higher! :B
I did something similar when testing my first Magnum 1012 inverter's charging function. I used ice cubes and a hair dryer to to ascertain that the unit was faulty. After the RMA I now have a good unit.
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
