enahs
Oct 02, 2013Explorer
Easy to do as described – wire from each 120 outlet to a common box with a plug that will accept your land line. I used good quality stuff (flexible cable, fittings, box with receptacle and lid, etc.) from Home Depot. Yes, there's a risk of a hot lead if a plug is pulled while the generators are running — or getting hit with a meteorite. But I used high quality plugs and they are very hard to pull out — never had a problem. My two Hondas easily run the AC. BTW, I have the proper shielded banana plugs but have never seen the need to install them (my Hondas have the receptacles for them).
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
