pianotuna
Jun 10, 2019Nomad III
Hi,
2000 watts is definitely in the large category, at up to 200 amps of demand (@ 12 volts). My own is 3000 watts and I've been known to draw 290 amps from the battery bank.
macscac wrote:pianotuna wrote:
There are those of us who use large inverters and load them heavily. In that instance 12 volt jars may offer better service than 6 volt units.
It is important to wire any battery bank in a balanced manner. See the link for directions.
Reserve capacity, just like the more familiar amp-hours may more than double because of the Peukert effect.
***Link Removed***
what is defined as a large inverter?
i allready have one small inverter but it runs the heater and lights. none of the 110 outlets work from it so I will be installing a second one to run an outlet to charge devices and a tv. thats pretty much it.
I was looking at a 2000 inverter from amazon.
