Mobilesport
Nov 25, 2016Explorer
time2roll wrote:
PowerMax does tend to drop to float 20 minutes after reaching 14.6 volts (at converter) and battery about 75% charged. The more amps the lower the state of charge when PM drops to 13.6 volts. Makes for a very long absorption time to 90+%. A second PowerMax may even slow you down.
If you are spending money on a converter to get a quick charge I only recommend IOTA or Progressive Dynamics.
Mine used to drop down to 13.6 volts after 14 minutes , I was told by PowerMax to remove resister 1 and it would then hold the voltage at 14.8 volts if I set it there , it worked!!!
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
