BFL13
Nov 26, 2016Explorer II
time2roll wrote:
How long do you want your battery at 14.8 volts?
How long will you be away doing something interesting?
Sure if you plan to be in camp all day or the activities are short it is not a concern. Or you can use the wind up timer like MEX.
Leaving camp with the gen running doing a battery charge on a timer would only work with a motorhome type of installed generator, not with portable gear like I have.
I consider myself stuck there during generator charging so I want to to recharge less frequently, and to get it done as soon as possible when it does need to be done. "It" being a 50-90.
So first, I want that 14.8 to stay at 14.8 for the entire 50-90 and using a timer is not going to tell me when I am at 90. I have to be there to see when I am at 90 so I can shut off the generator, put my charger(s) away and now be free to go somewhere till next time.
Solar is a way to extend the time between required 50-90s, so that is a good thing. When solar is not available, then it is all about the size of the battery bank and how many AH you use each day. To get the shortest run doing the 50-90, you need as many amps as you can put on the bank that it will accept. To run that many amps worth of charger(s) you need a big enough generator.
Your budget, your physical limits on how many batts you can take along, and how big a gen you can take along, are factors. Gas for the gen could be a factor. Another is the allowed generator time in the campground, where you need to get the 50-90 done in that allowed time.
That is why I am forever grateful that a few years back now, you taught me how to use more than one charger at a time to add their amps so it didn't take so long to do my 50-90s. :)
Since generator hours happened to coincide with the best time to go up to the lake for a swim, it meant battery charging was cutting into swimming time. You got me more swimming time! :)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
