robert3
Jul 12, 2013Explorer
Bionic Man wrote:
Am I missing anything?
Weight/transport: Will you be able to secure and use the new set-up okay? Most 3k generators will weight 80-150 lbs. A pair of smaller 2k models are easier to lift/move.
Value-per-watt: Price of a pair of 2kw units vs. a single 3kw unit from the same manufacturer are just a little bit more $$, but a full 1kw of extra power. In most cases, a pair of 2kw units will give you more watts-per-buck.
Service: 2 units, = 2 spark plugs, two fuel tanks to drain, two air filters, etc.
Flexibility: Nice to have 2 gens for other purposes. When power goes out, a single 2kw unit will get you by, and the other unit can be shared with family / neighbors.
Fuel Usage: Comparing fuel burned vs. watts produced, and at least for the Honda EU- models, the Honda EU3000is was the most fuel efficient, providing 1-3000 watts using less fuel than a pair of Honda EU2000i units (but not by much).
-Robert@Honda
Caveat: I work for Honda, but the preceding is my opinion alone.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
