BFL13
Jul 12, 2013Explorer II
another aspect of it all--
My H 3000 will run 130amps worth of Vector chargers (not PF corrected)any more pops the breaker. That is ok on my 458AH bank at 130/458 = 28% charging rate in bulk stage. With six batts 660AH? you could do 130/660 = 19.6% charging rate, so somewhat slower.
Point being the two 2000 gens would let you run more amps worth of charger for a higher, faster charging rate. You can do more amps with PF corrected chargers too. So----with PF corrected chargers you could do the 6 with the 3000 in good time.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 04, 2026
