cdcorpeExplorerOct 14, 2015parasitic drainMy rv has a 12 volt valve for the propane tank with to much parasitic drain, is there a way to leave the valve in the open position without the battery drain? ( it has a manual shut off) I tried a lar...Show More
Vulcan_RiderExplorerOct 14, 2015First, you shouldn't jump to conclusions.How do you KNOW that, have you measured it ?What device does that valve serve ??There probably is a 12 V valve so that the device can operate "automatically" and you wouldn't want to defeat it.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 07, 2026
Related ContentHouse battery drainBattery Isolator - Parasitic CurrentParasitic drawPower DrainGrey water tank won't drain completely
