cdcorpeExplorerOct 14, 2015parasitic drainMy rv has a 12 volt valve for the propane tank with to much parasitic drain, is there a way to leave the valve in the open position without the battery drain? ( it has a manual shut off) I tried a lar...Show More
bigfootfordNomad IIIOct 15, 2015I do not see anyone posting how much current this valve pulls.Most Dometic and Norcolds pull about .2 amps when the gas valve is on...15 min on time 2 times an hour is .4ah.... 24 hrs X .4= 9.6 ah per day.If that valve pulls about the same amps. .2 then 24X .2= 4.8ah per day.Guess I would not be worrying about the extra 4.8ah a day...Jim
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 07, 2026
Related ContentHouse battery drainBattery Isolator - Parasitic CurrentParasitic drawPower DrainGrey water tank won't drain completely
