ilandgreen's avatar
ilandgreen
Parking brake light and alarm comes on and cameras turn off
On my last RV trip, a house battery cable broke and shorted out on the frame causing one of the battery posts to melt away. When it happened the parking brake light and alarm came on, I lost the cameras, when I pulled over the steps wouldn't extend. I was able to disconnect the battery and crawled my fat but back into the RV and was able to find a place to sell me a new battery and cable.
Since that happened, I replaced all the house batteries and cables, but the parking light and alarm still goes off while I am driving, the cameras stop functioning. when I stop the stairs don't extend, the slides or jacks don't function. I am unable to see the voltage of RV batteries or the tank levels.
However, I have found a work around, when the issue starts, I hit the AUX battery boost switch and hold it down while I am driving. after holding it down for a minute everything goes back to normal. If the Generator is on it doesn't seem to happen.
The voltage on the RV batteries seems to be fine. Any thought?
  • ilandgreen wrote:
    After holding the battery boost switch, all goes back to normal, sometimes for 5 minutes other times an hour or two. If the generator is on it rarely happens if even at all.
    Sure sounds like a discharged house battery while driving. A voltmeter is your friend.
    Thinking logically if it was a fuse, the problem wouldn't be intermittent, would it?
    No
    Could the inverter have been damaged from the short and is causing this?
    Doesn't seem to be the charger since the problem doesn't occur with the gen running which would charge the house battery with the charger.
  • Could it be possible that you have 6 volt batteries that were mistakenly reconnected in parallel, rather than in series?
  • FYI "inverter" has become a slang term meaning: inverter OR charger/inverter OR charger OR converter.
    And yes a very high amp short like yours has the potential for additional equipment damage.
  • I am in the process of chasing all the connections up to where the battery shorted out. one of the cables goes to a 330a fusible link that isn't damaged, but another cable is connected to the same side of the fusible link as the battery terminal that winds it way along the rats nest of wires and cables. I hoping to locate where it terminates. Could the house battery Solenoid Switch be causing the drain? When I toggle the AUX battery boost it connects the RV and house batteries. thus giving enough volage to clear all the issues. If the issue is the house batteries draining, hitting that switch is like charging the house batteries with the alternator when I am driving. The part I don't understand is why those particular systems are on the house batteries.
    I was thinking the same thing
  • On your BCC's circuit board is an ignition relay that may have become damaged during your battery/cable issue. The contacts may be inconsistent.
    Richard
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
