BCSierra
Dec 15, 2015Explorer
Update for anyone finding this thread at a later date.
First of all, thanks enblethen for the suggestions. I did have a look at the Laurelhurst website but they don't list the BRC-10, probably too old. It's likely they or Eric's could help with some old stock but I was hoping to find something locally as I need the camper soon and didn't want to wait for mailed parts unless it was the only option.
As I was stuck in Vancouver with no heat for 4 days, I improvised. The initial problem was the orifice delivering a tiny flame, not enough to lock the pilot on. I initially took the tube off feeding the pilot and found it chock fully of rust, probably a solid 1-1.5 inches of the tube full. I cleaned it out, reinstalled the tube, and at this point, had way too much fuel. I guess the rust was acting as a bit of a regulator, just a bit too much. The orifice was rusted out so delivering way too much gas through the rust holes via the now cleaned feeder tube, making way to big of a flame. The interim solution was to pack some tinfoil into the pilot supply tube. Amazingly, it took a lot of tinfoil packed tightly into the tube to reduce the gas flow enough to prevent over-firing and resultant black smoke.
Edit, I forgot to mention that I tried to reduce the pilot by removing the cover screw labelled pilot adjust, and turning the screw inside as far in (and also out) as it would go with seemingly no affect on the size of the pilot flame. It must only work when the pilot orifice isn't messed up.
I found the pilot orifice and elbow at Fennells RV in Victoria BC so will install it tonight and hopefully no more issues for the next 34 years.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
