time2roll
Feb 09, 2018Nomad
Up to 45 amps. Will be reduced depending on state of charge and the wire that connects the battery and PD9145. If the battery is a bit low the wizard should put up to 14.4 volts on the battery for a faster boost charge for up to four hours. May take a bit for the voltage to climb to 14.4.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
