Fisherguy's avatar
Fisherguy
PD charge wizard not working
Since I put the solar panels ontop of the trailer I haven't used the PD 9280 I put in a few years ago. When I parked the trailer a while ago in the RV Port I plugged in the trailer my trimetric showed the converter was not putting out many amps, then I noticed the LED on the wizard wasn't lit up and pushing the button didn't do anything either.
It's stilll plugged in, I removed the jack and plugged it in again and still can't get the converter into bulk mode.
So my question is do you think the issue is the wizard or would something be wrong with the PD9280?
Thx
  • Batteries were at 66%.
    It was charging the batteries but not in bulk mode, and like I said I disconnected and reconnected the wizard phone jack.
    The LED of the Wizard should normally be on when the PD is on.
  • What is the battery voltage?
    Consider disconnecting the panels and check the PD operation next day. With the wizard light out I suspect an open power circuit to the battery or 12v system. Possibly the wizard communication cable was disconnected.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
