MEXICOWANDERER
Oct 23, 2015Explorer
As antimonial flooded batteries age, antimony migration to the negative plates can increase watering frequency by a factor of ten. Too high of float voltage can drastically increase antimony migration. Once electrolyte gravity maxes out, that's it. Reduce voltage. Most car jar RV batteries require a 100 or so milliamps to float at 20c to maintain correct float.
5% antimony batteries need more frequent watering right off the starting blocks. 7% antimony batteries used on WW2 submarines really used up water, 500-700 gallon stainless steel tanks mounted next to the maneuvering room with hoses leading down to the forward and aft battery.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
