DrewE
Oct 26, 2015Explorer III
Salvo wrote:
If you don't know what you got then you're in the dark.
Here's a 60A PD that only outputs 24A and declines from there. It takes the PD about 100 minutes for it to get to 14.4V.
I wonder if the fan in the converter was not working properly or it otherwise had inadequate cooling. It starts out at 44A or so, but after a very short time (a minute or two, maybe?) is much lower. The curves do suggest that it's neither being voltage nor current limited.
