Salvo
Oct 27, 2015Explorer
Did I say there's a dc transformer? I don't think so Doug.
We do have a transformer with a primary center tap connected to 170Vdc. The primary end taps connect to the switching fets. They are controlled by the pwm regulator. That's how all these converters work.
doughere wrote:
All converters have:
1. a peak charge circuit (diode & capacitor) front end that converts ac to 170Vpeak dc.
2. a transformer that drops the 170Vdc to usable levels.
3. a pwm controller (and power fets) that controls transformer switching to achieve the desired output voltage.
4. diodes & inductor/capacitor filter at transformer output to convert pwm waveform to a dc level.
The regulated output voltage is:
Vout = Vpc * Np/Ns * pwm
Where:
Vpc is the peak charge voltage
Np is the number of primary turns on the transformer
Ns are the turns on the secondary
pwm is the percent duty cycle of the controller
Where do I find one of these dc transformers you're talking about in item 2. I been around a while, and I've never seen one of these.
