doughere
Oct 31, 2015Explorer
RJsfishin wrote:
Quote:
As for the spec you listed, that's without the wizard. With the wizard, per chart, it is supposed to pop up to 14.4V immediately. In reality, it takes an hour. What gives?
Whose reality ?
At 50% discharged, my PD (in bulk mode) has never been less than 14.2-4 v on startup. Believe what you want to.
X2
I originally installed a PD9245 (when I had a 1K gen), later changed it to a PD9260 (when I got a 2K gen). The PD9245 is doing just fine in a friends rig. Both units always started at or near 14.4. I've seen the PD9260 put out near 60 Amps on start up into a well discharged pair of GC's.
Doug
