And Sal, with all your posts, you are well aware (I am sure) that it was a loaded statment, as voltage will not rise if max current is being delivered.(As it is being current limited at max, no matter what mode it is in) It is only at a particular point along the charging curve, with a certain load, that current and voltage will max, because below which either current will be limited by it's set maximum, after which voltage will creep up as current drops to maintain output, followed by voltage being regulated. So the issue of not getting max current at max voltage is only relevent during that "cross-over" point of the charging curve. Which I might add can be a very brief period. But the point is the same, the PD delivers most of it's rated current at >14.3v.
