Salvo wrote:
You got (sic) a reading comprehension issue. I said the PD will not charge a battery at rated current.
Oh really?
Salvo wrote:
The problem with the PD is that when in boost it will not supply rated current. It never supplies rated current because output voltage is unable to rise to 14.4V. .....
Again Sal, you are flat out lying. Another demonstration class. There is the quote. Why suggest something so ignorant as a reading comprehension issue, when you cannot articulate what you are thinking.
My point was valid. The charger does not care whether the load is pure resistive or not. It all comes down to impedance. The test I showed was valid. I won't flaunt credentials. Your's seem made up given your bias and integrity. Quit trying to pass off opinions as facts, by hiding behind some alleged qualifications. Thanks for polluting yet another converter thread by starting the insults.
We all know the PD has a voltage sensitvity shortcoming. In all other respects it is a very good charger.
