liborko wrote:
I think you should give serious look at Xantrex Truecharge series of chargers(40A & 60A) or Prosine 2.0 if inverter/charger desired. Prosine charger section has 100A charging current limit. These chargers are programmable, are pf factor corrected, have a provision for temperature sensor, monitor panels
Thanks. I looked at the Truecharge and liked it, but as I studied the information I could find about various multi-stage converter/chargers I became caught up in all the detailed information available about the PD through the patents. There's something about having a nearly complete circuit diagram and a description of circuit operation that gives me a warm fuzzy that if something goes wrong, I've got the information I need to fix it.
If Xantrex had comparable information about the Truecharge available, I might well have purchased one.
If I needed an inverter, I'd look at Prosine, but I'm happy with the one I've got.
