BFL13 wrote:
I really like having the Trimetric for seeing what amps are being used/put in and the accumulated AH. I use the voltage read-out too, but could get that with a simple voltmeter before and still can where I want to see it to two decimal places.
I find the single decimal voltage of the TriMetric to be useless. For many years, I've included a rotary switch selectable two decimal voltmeter in my RV panel. I can check voltages at any one of three battery systems (coach, chassis and gen) and the voltage on the RV electrical system (which is independent and can be switched to any of the three other systems or the converter source).
Adding the TriMetric to the voltage monitor has been great. Like you, I care about amps in/out in real time and totalized over a period.
