KendallP wrote:
I would have to agree with you about the dip in charge rate prior to the 4 hour mark. The thing is not designed to go over 14.6 (or 14.55) Volts and it takes a reasonable differential between charger and battery to continue pumping in the power.
Yeah. If you look closely, you can see that the voltage has leveled off at about 3 and a quarter hours. The Trimetric voltage output is only a single decimal point, so we can't see changes in that last tenth of a volt, but IIRC, the raw data is constant in that region at 14.5.
