BFL13 wrote:
When I jacked up the voltage using the pots in both my previous Paramode 55 amper and now the PowerMax 100 amper, I also messed up the voltage meant for floating when on shore power
One of the nice things about the PD circuit is the way it switches between the three voltages for float, boost and normal modes. They are relatively independent so I can jack up the boost mode voltage without having any effect on the other voltages.
Up to this point, I haven't seen it in boost mode except when I intentionally/manually switch it to boost mode.
