I'm not asking about ac voltage. What is the dc voltage (after rectification) at full load?
Calculation for minimum dc input voltage:
Vmin = (Np/Ns) * (Vreg + Vd) / pwm_max
Where:
Np/Ns is the primary to secondary turns ration of transformer
Np/Ns = 13/2 = 6.5
Vreg = 14.4V
Vd = diode voltage drop and other IR losses = 1V
pwm_max = max duty cycle = 80%
Vmin = 6.5 * (14.4V + 1V) /0.8 = 125Vdc
If your input voltage is that low then the only way to fix the converter is to replace the transformer. The transformer requires a lower turns ratio. Or, install a big-ass 120Vac step-up transformer on the front end.
If the converter suffers from low input voltage, then PD really mucked-up their design.
Sal
DryCamper11 wrote:
Salvo wrote:
Have you measured the dc input voltage to the center tap of the push-pull transformer under heavy load? I did a quick calculation and determined you need a minimum 125Vdc to output 14.4V.
No, and I'm only getting about 105-106 volts AC under full load from the limited AC voltage on shore power at the RV.
