NinerBikes wrote:
Salvo wrote:
If anyone is looking for a fast battery charge, or doesn't want to run the gen for longer time periods, then going with a different converter is a better option.
Sal
DryCamper11 wrote:
You can review the performance tests from the graphs posted in this thread.
But I'm good with a PD 9245C, a pendant, a Honda EU2000I with pure sine waves, 2 GC-2 batteries at 225Ah, and a short run of 3 or 4 feet of 6 gauge copper wire to handle the 45 amps to the battery, correct?
In theory those wire gauges should be ok, but IMO you would be better off with #4. Certainly use #6 instead of the #8. It might be from connection losses that it seems to go better if you "over-do" the wire gauge.
I use deck- mounted converters close to the batteries and you do get a few more amps with fatter wire even at the short lengths involved
