Vintage465's avatar
May 31, 2021
PD Vs. WFCO
So my plans have been to replace the WFCO converter in my 2015 20fw with a Progressive Dynamics retro-fit unit that essentially replaces the converter using the same 120v/12v power center. Part of this retrofit would be to replace the existing #8 conductor that goes from the power center to the batteries with a #2 to minimize loss over the length of the run. I would be doing this specifically for emergency charging if we were somewhere and the solar couldn't keep up with due to clouds. I know the WFCO units are considered pretty crummy compared to the Progressive Dynamics......But reading further, in the manual, the WFCO is "smart"(maybe not a genius) and has a 3 stage charging profile. Charges bulk @ 14.4, for 4 hrs which isn't great(the 14.4 part) but would probably work ok. Then it backs off to 13.6 for absorption mode and 13.2 for float. Since they are both multi stage charging units with similar profiles, what is the real advantage of the P.D.? Must be something better about them as Lance and ORV are using P.D. now in their coaches.
  • 2112's avatar
    2112
    Explorer II
    I've owned 3 WFCO converters over the years and have never seen anything but 13.6V out of them. Smart they are not.
  • 14.4V is good but the 4 hours of bulk charging is not. The time should adjust to the battery charge level. A charged or partially battery should quickly enter absorb or float mode with reduced amps and voltage and stablize at a float voltage of 13.4V.
    The actual mfg battery specs may vary slightly from the above.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    Problem with WFCO is they very very very seldom ever go into the bulk charging mode. So.... your almost or always stuck in the absorption mode for charging which is very very slow on a discharged battery.
    Starting with the #8 wire if it is of any length the WFCO will likely never go into bulk mode.
Having RV issues? Connect with others who have been in your shoes.24,345 PostsLatest Activity: Dec 11, 2025
