PN, wets cells won't take any more current UNLESS you hit them with higher voltage same as AGMs. 14+V at 97% SOC or whatever won't cut it. Too much resistance even with AGMs. A finish charge is needed to get that last bit in there. As far as I know, AGMs need the same deal based on HiTech's testing with his AGMs (wish he was still here). He actually figured out how to charge them properly and know they were fully charged. With AGMs you have to be careful not to make them outgas too much with the finish charge which is where temp compensation comes into play. BTW, Mex likes kilowatt-hour meters when using AGMs.
