full_mosey
Oct 29, 2013Explorer
My 8a24M Deka has a temp/volts chart in the manual.
Generally, AGM mfgrs strongly advise using temperature compensation chargers that increase charging volts at lower battery temps and conversely lower charging volts at higher battery temps. Battery life can be affected by over/under charging.
If your charger has a battery type selection, but not any temp comp, you might choose a battery type that best approximates this adjustment on a seasonal basis. I switch my solar controller between sealed(14.1V) and flooded(14.4) by using 14.1V during the hottest summer months when my batteries reach up to 110F.
HTH;
John
HTH;
John
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
