I was trolling Best Converter and ran across a 9200C series doing bulk at 14.8v. Seems only in 45A for now. http://www.bestconverter.com/PD-9245C-148-45-Amp-RV-ConverterCharger_p_610.html#.VWPmaI9...
"KJINTF, the suggested 60k resistor on pin #5 will not change Normal or Float mode?"
Modified a few of the PD's - They keep a rock solid 13.2 / 13.6 / 14.9 (14.9 is set by the resister size)60K is only a suggestion - you will need to experiment
Did a similar modification on my WFCO 75amp plus added a remote control which manually selects 13.2 / 13.6 / 14.9 works good to shorten gen run time
