Dutch_12078
Aug 08, 2021Explorer III
wa8yxm wrote:
I would go with a pole mount on the ladder... Put it up and peak it .. Then return to ground.. take it down to move....
Three As I recall those antennas need to be | not /
Time to learn something new, John...
Polarisation diversity
To take full advantage of MIMO, (currently used in 4G LTE communications), two antennas must be used.
When installing directional antennas like a Yagi antenna, the first antenna must be rotated horizontally to a 45 degree angle and the second to a 135 degree angle. This is because of "polarisation diversity".
LTE uses polarisation diversity to help distinguish between the two data streams sent from the tower.
Guide to Understanding MIMO
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 14, 2026
