Interesting conversation. One poster at the Airstream site stated you cannot use sharkbite fittings with PVC. I will be connecting 3 PVCs to a T similar to the one in the picture, if possible.
Have you guys and dolls used the gray PVC with Sharkbite fittings before?
mlts22 wrote:
Read this note before installing Sharkbite fittings. There are some better alternatives out there, one is similar, but made out of plastic and doesn't depend on a single O-ring to keep your pipes from leaking.
The upside is that Sharkbites are easy to use, and don't require expensive, specialized tools to install.
