MauryFrench's avatar
MauryFrench
Pipe Repair in RV
Good day, all. After the marvelous help I got with the Water Heater Pilot, now we have a water leak. I found the leak; its in a 'T' of the gray PVC. Is that schedule 80? Anyway, it is in a very tough place to work, so I wonder can I just cut out the 'T' and replace with Food Grade hose and hose clamps?
Also, any thoughts on what size hose that is?
Thanks in advance. I know the proper thing would be to properly replace the pipe, but I just don't see how I can do it.
  • Hi,
    Sooner or later the grey has got to go. Better to do it before it causes serious water damage.
  • gbopp wrote:
    Definitely use SharkBite Fittings and Pex.
    Ditto on the sharkbite. You may want to invest in a decent tubing cutter also. Sharkbite fittings work better with smooth straight cuts on the tubing.
  • Ooh, I forgot about the sharkbite fittings. I will look at those and the PEX. I cannot quite see myself refitting the whole trailer just yet though. That would be a project.
  • Probably 1/2" pex if it's a waterline......sharkbite fittings from local home center.....
  • Hi,
    The grey pipe is defective. Pull it all out and replace with pex.
