CaptSailor
Mar 15, 2015Explorer
smkettner wrote:
Transfer switch has two input and one output. Connect the inverter to one input and the main cord to the other input. The output goes to the distribution center. Wiring diagram should have been supplied with the switch. Plug the cord into the generator.
Yes the solar direct on the battery is independent and no change needed.
Thanks for the quick response. Well, that's what I initially thought. But if I do that, the inverter will be providing power to the entire trailer, including the converter causing huge power draw.
But I guess at least this way I only have to do one thing...unplug or turn off the converter. When on inverter power.
