time2roll
Mar 15, 2015Nomad
Go Power has a transfer switch that will break out power for the converter.
Otherwise you may need to add an inverter sub panel to break out what should stay off inverter. Or use separate transfer switch for each branch circuit.
Is the generator built in with remote start?
I assume you have a remote for the inverter?
50 amp or 30 amp RV?
What do you really expect to run from inverter vs generator?
As long as you are moving wire you may as well get this the way you want it.
