azrving
Apr 12, 2018Explorer
Did you notice that the installation instructions say this
"Allow 5 inches of space between the back and sides of the appliance, which allows the proper
air circulation to cool the compressor.
I installed THIS Whirlpool two years ago. It has a rear coil so the clearances can be much smaller. It pulls point .6 amps so the DC running amps are 6 to 7. I run it along with other items on a Xantrex Prowatt 2000 and it's 10.7 cu feet. It can accept an ice maker but I opted to make a freezer shelf out of plexiglass with a thin aluminum edge.
I dont recall but I think defrost pulls about 20 some amps DC and last 10 min or so and it's no big deal.
I dont see a defrost circuit in the Avanti wirig schematic but the owners manual says this.
" When
? For the most efficient operation and minimum energy consumption
, defrost the
appliance compartment when the frost on the appliance walls is excessive or ¼ inch thick.
There is no need to defrost the refrigerator, because ice depositing on the inner back wall is
defrosted automatically. Ice is depositing on the inner back wall during the compressor
operation; later on, when the compressor is not operating ice is defrosting and water drops
collect and drain through the outlet in the inner back wall into the drain pan situated above the
compressor, from where it evaporat
es.
How?
CAUTION
Do not use boiling water because it may damage the plastic parts. In addition, never
use a sharp or metallic instrument to remove frost as it may damage the cooling coils
and will void the warranty. We recommend using the plastic scraper.
Reset the thermostat to “
0” position and disconnect the power supply.
Remove the frozen food from the appliance and place it in a cooler to protect the food.
Leave the door open for a while so that you can easy scrape off the frost.
Use a plastic scraper
but be careful not to damage the inner surfaces of the freezer.
Wipe up the scraped frost and ice before it is completely defrosted.
It may be a manual defrost.
I dont recall exactly but I think I went 5 hours or so with mine shut off before the temps got lower than we like so I never bother shutting it off. No reason to as the solar more than covers it and battery charging. In your case if you have decent size wire in your vehicle (usually 12 gauge) you wont have any problem running it. If you want to overnight on your batteries I think you may need two 12 volts or go to 6's. During defrost it's a pretty good load load for one 12 volt so two may be better again if your vehicle is running it will probably be fine. My Whirlpool does a defrost at some interval but it also does a defrost each time I disconnect power and turn it back on so that cuts into any savings of shutting it off while traveling.
When you start the r&r consider the depth of where the front legs will sit as you may need some type of lumber to support the front. The frig will hang out of the hole about 4 inches so door can open.
Edit: I might also wonder that if the Avanti pulls 15 amps at start which is 150 amps DC that it might drop the voltage too low on a single battery.
" When
, defrost the
es.
How?
CAUTION
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
