GordonThree
Aug 06, 2018Explorer
Brettmm92 wrote:
The main question I have is what piece to look for to establish the plumbing on the barrel. Specifically, I'm going to make a hole in the barrel so the piece that connects to the barrel (and ends up becoming a showerhead) has to have two bigger pieces on the outside and inside of the barrel. For example, when you drill a hole for a bolt you sometimes use a washer on each end to compensate that the bolt is smaller than the hole. And a recommendation on materials would be great.
Thanks ahead for your time, all input is appreciated!
Is this going to be stationary on a tower, or portable, on your RV roof somehow, or what?
You want something called a bulkhead fitting, like 1" should work in your application. Available at Home Depot, Lowes, etc, it's a piece of pipe that's threaded inside and out. It has a flange on one side and a large nut that compresses gasket material on either side of the barrel wall. From there you can thread in something like a hose bib type faucet, or one of those spring loaded outdoor shower type faucets like you sometimes find at a beach or public pool.
Just sitting in the Sun, your water will reach shower temperature in about a day, based on my own experience with a 65 gallon aux water tank I have in my truck. A tarp might be required to keep the water from becoming so warm that it becomes uncomfortable, or starts to deform the barrel.
Also consider microbial control. Untreated water just sitting in a barrel is going to grow algae and other microbes. Chlorine is an option to combat this, or livestock tank treatment like barley hay. A bundle of barley hay will last at least a season, it might be the better solution.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 15, 2026
