Gdetrailer
Jul 30, 2019Explorer III
Wadcutter wrote:
Use the spray on tire cleaner or what manufacturers call tire shine. Various manufacturers make their own stuff. Can get it at Walmart or any such store. The kind you spray on a tire and let it set. Some are no wipe, others recommend wiping it on. Extremely easy to use. Spray on and forget it. Doesn't hurt paint or chrome. Brings rubber and plastic back to shiny black finish again. I've used it for years on the RV trim and tires, car and truck tires, black plastic trim on vehicles like around the bumpers, truck beds. Also use it on the inside like dash, door panels, instrument panel, etc. Anything with black plastic pops out bright shiny black. It's what used car dealers use it on their cars before putting them on the lot.
Don't paint. Paint will chip and peal then look worse than what you have now and you'll have a mess trying to get it to look better after that.
Obviously you have never tried Krylon Fusion paint for plastic.
I am not a Krylon fan by any means but the Fusion paint is not the same paint that you are referring to.
Fusion creates a molecular bond to the plastic that will not chip.
So far, it has held up extremely well for me, I had painted the door window surrounds 11 yrs ago, not one chip or change in the color.
Painting plastic with paints made for plastic will not only be one and done but also do something that none of the slather on concoctions can do, protect the plastic from UV indefinitely.
You truly do not understand the idea that you are no longer a slave to reapply then reapply then reapply over and over until you sell it.
You can also use these plastic paints as a primer for other paints, so if you can't find the color you want, hit the item with the plastic paint as a primer coat, then go over that with the paint color of your choice.. It will stick better than you think..
Gets pretty good reviews and tips on Amazon..
HERE
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
