LarryJM
Jul 31, 2019Explorer II
dpgllg wrote:
While washing my 5th wheel I noticed that the plastic trim around the wheel wells still looks dirty although I have tried everything to get them clean. I washed them with different cleaners and even used my pressure washer on them,
What can I do to get them looking good again? The 5th wheel is only a little over two years old.
Thanks!
Dave
Personally, I would use either Colorbond or Plasti-Dip instead of any paint. I used Colorbond on my vinyl hose carrier back in about 2010 and Plasti-Dip around the same time on my ABS trim pieces (wheel well trim, LP tank cover, and even the aluminum skirting along the bottom of the trailer). Both have held up suprisingly well. I like these two options since you can periodically used 303 to add aditional protection. The Colorbond is permanent whereas the Plasti-Dip can be removed and refinished with something else.
Larry
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
