mrad
Oct 10, 2020Explorer II
wopachop wrote:
I see this as a noise level issue. Not really a battery issue. You only boondock 3 days a year, and your trailer has a huge built in generator.
Need to decide if you will feel uncomfortable running the Onan at times because it might bother neighbors. If that is the case then bring the Ryobi. You will get a feel for how long charge times take. Worse thing you could do is ignore the built in genny. Actually want to start them every month if you have the discipline and ability. I know people who store trailers hours away so they can only cycle the generator and ACs when they go camping. Which for most is not every single month.
There is a secondary issue, although not as important. in th ewinter, I have a fishouse that I stay in for the weekend. I usually use the ryobi to power the satalite, tv, lights, and pizza oven. However, recently I have been using my deep cycles to power it in the evening to keep the noise levels down. I would now use the GC batteries in the winter at the fishouse also.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 25, 2026
