The time to stay at Vabs before dropping to Float voltage "depends" It depends on how long it takes to do the absorption stage on your size of battery bank with your size of solar set with how much sun you are getting that day.
My routine with the Solar30 when I was using 12v panels was set it to 14.8v and leave it there. It would get the batts to that in the afternoon sometime on nice days. When camping I don't drop to Float since there is no need to with my routine. Battery usage brings voltage back down later in the day and then it gets dark.
If you have a big solar set and a small battery bank or don't use many AH, you might hit Vabs by mid morning, so now you might want to drop to a Float voltage. No big deal to reset the controller when convenient. Just push a button.
I would set it to a Float voltage when not camping and the batts are already full before "storage" if I didn't have shore power to do the Float using the converter.
You can be a "controller snob" or just get what works perfectly well and ignore the snobs :)
