BFL13 wrote:
smyke wrote:
I haven't decided yet.
My head needs to stop spinning. ;)
I was going to ask for suggestions on better controllers in the $100 range.
Thinking of also going 24v with MPPT since i found some quality (at least to me) panels on dmsolar.com. but I am not really sure how to read the specs on those panels. Somehow i think that 8amp from 250watt 24v panel must be "better" than from 150w 12v panel.
Am i making sense?
No. :)
With PWM you get the panel rated Isc as your amps to the battery when the panel is aimed at a high sun. This might only be for a minute a day at high noon while the rest of the day you get fewer amps with the sun being lower and off to the side of a tilted up panel facing South.
With MPPT you ignore the rated Isc and the rated Imp and only look at the watts. The amps to the battery are what is left over after you get your "output watts" and divide that by the battery voltage of the moment.
It is very wishy-washy how many amps that turns out to be, but generally it is less than advertised. The MPPT sellers like to brag about how many amps you will get at battery voltage of 12.1v, but don't like to talk about how many you get at 14.1v
The critical factor is that your MPPT 24v input watts is entirely dependent on panel temperature which gets hot in the sun and kills the panel voltage and so its watts and so the "input watts" to the controller.
Subtract whatever the controller loses from its inefficiency bucking that 24v down to 12v, which also depends on temperature (hot is bad) and now you get your output watts to take some amps from.
But you are still not out of the woods, because the higher the battery voltage, the fewer amps you can get from the same watts!
So now you are going crazy, with the sun going up and down messing with your amps, plus now the battery voltage is climbing, messing with your amps, and there goes your MPPT "advantage" over PWM.
The only excuse to have MPPT is if you need to go 24v panels because they are cheaper per watt, or because you have roof real estate issues (although many find it is easier to go several smaller 12v panels in between roof obstructions, than find a spot for a big 24v panel or two.
Not to mention opportunities to aim the panels or not, where it is easier to move around (aim) smaller 12v panels in a portable configuration than big 24v panels to set out and put back (where?) every stop.
You need to get your camping scenario sorted out, and go from there.
If you can't do that then just get a little solar now and learn from that. Then get the "real" solar set, now you know what works for you. That is allowed (recommended , in fact), and it might even turn out your "learner set" can be part of your final set.
I agree with BFL13 but with that being said it would not hurt to plan for the future. You talked about a inverter. It is likely your power wants will grow. Of course several systems would not be the end of the world. You could adopt a phased in approch. You could as an example buy a bogart engineering SC2030 solar charge controller. As a stand alone unit its ok but will handle 540 watts of panels for future expansion. Then later you could add the TM2030 to turn it into a fully adjustable solar charger with a battery monitor. You can get the SC2030 in the 120s range at best converter. I would suggest that you download the SC2030 solar controller manuel at bogart engineering.
