pnichols
Nov 02, 2017Explorer II
BFL13 wrote:
I turned the voltage down to 13.7 for the night and this morning (at 0.01 amp at 13.7 for the pair) turned it back to 14.8 to see if amps would drop to zero like Phil gets as his idea of Full. (Only he does that with 13.8) So amps were back up to 0.9 again at the higher voltage, but later I noticed 1.0 and then 1.1 so amps were rising slowly. Same voltage.
After "charging" (fixed voltage converter) at 13.7-13.8 volts until the current flowing into my two paralleled AGMs is near zero ... and then starting up the MH engine to hit them with 14.2-14.4 volts for a minute or two ... the current into them does not change - it still reads near zero.
So this means I've not done the "full check" test as BF did, because I only left the higher 14.2-14.4 voltage on them for a minute or two after charging them for hours at only 13.7-13.8 volts while observing the ammeter.
Do all the comments in this discussion thread make it clear to me that I've never been charging my AGM batteries up to full by only using my stock converter (most of the time) and the engine's alternator (part of the time) even though the ammeter indicates that current flow into them drops to near zero after hours on the converter - NO.
I've still never read a definitive technical explanation stating unequivocally that to fully charge a dry (AGM) lead acid battery one MUST charge using voltages in excess of 14 volts. All I've ever read implies only that one can charge FASTER using voltages in excess of 14 volts for AGM batteries.
So far per our camping style and being sure to use AGM batteries with a 13.5-13.8 volt float spec, our charging method has kept me from not having to replace our stock 7345 Parallax converter.
If I'd stayed with liquid acid batteries there are solid electro-chemical reasons - beyond shorter recharge times - for at least some of the time hitting them with higher voltages than what a stock converter outputs.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
