BFL13
Nov 03, 2017Explorer II
Phil, to be clear, did the first set of AGMs have the 14.x charging spec and the linked info from that same company didn't care if you used 13.8 instead--or is it just the new batts that have the 14.x spec and you are going by the advice of the other company for the first set of batts' specs?
Just making sure it is apples to apples. Your actual results might be distorted by that alternator charging they get besides what the converter does.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
