pnichols
Nov 03, 2017Explorer II
BF,
Both of my previous Interstate AGMs (built by C&D Technologies) said on their labels to use 14.X volts for Cycle Service recharging and my current Fullriver AGMs recommend the same for Cycle Service recharging.
NOWHERE, have I found in writing - electro chemically - an explanation of how AGM batteries are ruined by using less than 14.X volts for recharging. They MUST be periodically fully recharged however - which I use a built-in ammeter and a lot of time at 13.8 volts and a little time at alternator voltages to do.
Liquid lead acid batteries are of course another story. Stirring of their liquid (bubbling during charging due to using high enough voltage) makes a lot of sense in order to periodically restore uniformity of their liquid's chemical makeup. Plus, probably other chemical reactions at their plate-liquid interfaces are needed to restore plate surfaces eroded by the battery liquid over time ... and periodic higher recharge voltage may drive these reactions.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
