landyacht318
Nov 03, 2017Explorer
Define performance after a full recharge.
For me it is voltage held under load for Ah removed, and Mex's coined term of 'trends and tendencies.'
I've compared the two, slow recharging at 13.6 to 13.8v, until amps taper to near zero, then boosting voltage to 14.7 and seeing how long it takes for amps to taper to near zero.
And then comparing the voltage held under load after the 50% depleted 90Ah battery is brought to 14.7v at 40+ initial amps and held at 14.7v until amps taper to near zero. Almost as fast as the battery can be fully charged, within say 20 minutes.
The latter sceanrio obviously heats the battery more, which would make it appear to have more capacity and perform better the next discharge the next night, but it does not explain the better performance the following night after battery has cooled, or subsequent nights after the high amp recharge to full was performed.
So we can say the AGM battery is full by how many amps it accepts at absorption voltage, or have observations of dozens of cycles recharging at and to different speeds and voltages.
My Thin plate pure lead Northstar AGM Loves the high amp recharge, performs way better after receiving such, it will soon be 4 years old and have approximately have 700 deep cycles on it, many of those well below 50%.
It still easily cranks my 65f degree engine when deplted 65 of its original 90AH, and my voltmeters show that in this state of depletion, voltage remains over 10. It still rebounds to over 12.2v after removing 45AH from it. when it has recently gotten the high amnp recharge to full, but will not rebound as high when it gets the lower and slower 13.6 to 13.8v for the usual 36 hours i give it when i do plug in and recharge slowly to full and can't be there to manually lower voltage from 14.7v
The high amp recharge increase in performance is also noticeble during engine starting, how fast it occurs and how low the voltmeters register during engine cranking. Their refresh rate throws some uncertainty into this, but I have two digital voltmeters on the same battery right next to each other, as I no longer have a house and an engine battery but the same 90Ah battery for both and the sense leads are right on the battery terminal on one and further away on the other.
Not going to paint all AGMS with the same brush, but the Northstar loves the high amp recharge, and no way will I deliberately slow down charging, unless I will not be there to lower my meanwells set absorpotion voltage when the amps taper to 0.5% of capacity.
When I do do the 13.6 or 13.7v charge to full over the 20+ hours required, is when I notice the voltage sagging more under the next discharge, and sagging more as it cranks the engine slower.
I've observed this dozens of times. It is repeatable, and overwhelmingly obvious when low and slow 13.7v did its thing compared to a 40+ amp blast until 14.7v was attained.
I will not intentionally slow charge My well depleted AGM battery, and consider the high amp blast to be restorative when the battery appears to become lazier from repeated low and slow to full.
My starter is rated at 1.4KW, and my dashboard ammeter which reads to 100 amps will always display FFF when cranking the cold engine indicating over a hundred amp draw
I view each and every engine start as a mini load test, each overnight discharge as a longer load test, and have many hundreds of nights of observing the behavior of this specific AGM battery with an Ah counter to see the voltage held for how depleted the battery is, and I often rezero it.
And no way in heck will I call recharging at a max of 13.8v, just fine. I point fingers at noone here in the following sentence, mostly users on some other forums. In my opinion 'just fine' proclamations are usually made by the overwhelmingly ignorant who cant and don't have the ability to understand, all they know is thier methodology has not yet caused failure, but not being able to measure capacity or performance decline or accrue any data at all, any 'works just fine' claims, will and should, in my opinion, be ignored, as 'works just fine' could and often does simply mean 'has not yet failed, but could, tomorrow.'
Try the experiment BFL, deplete to 50% and charge at 13.8v max for however long it takes for a goosing of 14.7ish v to have amps taper to near zero, then observe overnight and morning voltages.
Then do the full recharge at high amps until 14.7v amps taper to near zero and try and replicate the same variables when discharging. I bet the high amps will hold higher voltage for longer with the same AH removed, even accounting for the high amp recharging's higher battery temperature.
Whether the higher amps leads to more overall cycles from the battery before failure, is unknown, but my many observations of My AGM, make me believe it does.
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
